Level Lines
Level Lines
chris.slattery
Level Lines
chris.slattery
I have level lines in elevation and section views that extend approximately 2000000 feet beyond the model. There is no view template attached. It is not all level lines just two. Does anyone know a fast and easy way of getting them back in line with the others?
hmunsell
what i usually do it zoom in to the end of them and select the grip and drag them back. this will probably need to be in the N/S and again in the E/W elevations. once there back, slide them inline with the other levels and they should lock together.
Howard Munsell
craigjonnson
Crop your view, select a grid line > right-click > select objects in model. Right-click on the gridline and pick reset to crop.
