Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Layer from BS1192 to Uniclass (UK)
9 REPLIES 9
Message 1 of 10
Dave_P
742 Views, 9 Replies
Hi All,
I was wondering if any of you have already been able to mapping and converting the layer txt file in Revit from BS1192 to the Uniclass standards.
Would you be able to share it? it would be definitely a good starting point for the people that still work across 3D and 2D.
Does Autodesk intend to implementing it anytime soon?
Thank
D
9 REPLIES 9
Message 2 of 10
RobDraw
in reply to: Dave_P
The "whole industry"?
Your assuming that everyone in the industry needs to do this. Not true. There are many more people that do not need this function than do.
Rob
Message 3 of 10
Dave_P
in reply to: RobDraw
better?
Message 4 of 10
RobDraw
in reply to: Dave_P
Not at all. Going from 3D to 2D doesn't necessitate those standards.
Rob
Message 5 of 10
Dave_P
I understand that this is might not be best practice but it is necessary if the client work in this way and although the conversation it is not as accurate as it could be is still better than starting from scratch.
Can you help with the topic?
Message 6 of 10
RobDraw
in reply to: Dave_P
It's got nothing to do with best practice. Why don't you just say that you have a need for it instead of making it sound like there's some sort of global need for it?
Rob
Message 7 of 10
Dave_P
of course I need it. or why would I write this post. and there is need. because people work with BS1192 standard, the AEC(UK) Cad, the Cl/sfb etc, so yes, there is a need. but I'm not here to discuss this so I'll ask again, can you help?
Message 8 of 10
RobDraw
in reply to: Dave_P
I don't think so. I wouldn't try to tackle this in Revit.
You need to stop muddying the waters with useless extraneous information and simply ask for what you want.
Rob
Message 9 of 10
iainsavage
in reply to: Dave_P
I did a search to try and find an answer for you but I see that you got there first.
https://forums.autodesk.com/t5/revit-structure-forum/loading-layer-names-classification-codes-accord...
Message 10 of 10
iainsavage
in reply to: Dave_P
….and this
https://anotherbimblog.blogspot.com/2017/08/revit-cad-export-layers-to-uniclass-2015.html
Does the BIM Operability Tools for Revit classification manager provide a layer naming table or does it only classify families?
Forma Design Contest
