Latest Updates | New Knowledge Network Articles | Revit MEP
matthew.d
Alumni Alumni
matthew.d
Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and/or updated for Revit MEP?
(List shown in chronological order)
Subscribe to receive updates for new Revit MEP Knowledge Network articles.
For more updated solutions, check out the AutodeskHelp Blog!
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
December 2017
Collaboration for Revit - synching fails with error loop
Preview is not showing all objects from a certain view when printing to PDF or printer in Revit
Revit 2018 Products, stuck at loading…..
The VR view is pulsing in Live editor when no thickness model imported into Revit
Revit LT do not have BimObjects online
Revit 2017: Model Open dialog icon shows A360 instead of BIM 360 Team
Revit 2018 Steel Connections keeps showing as an outstanding update in ADA although it was installed
Revit 2017 Material does not have same appearance as in Revit 2016
Revit 2018 keeps running in viewer mode
Revit: P&ID Modeler dialog stuck on screen
How to make wall opening to be considered in analytical model
Fall Creators Update causes issues with Webroot and Revit
How to change analytical node size
How to export Analytical Model to Tekla
Installing Revit or Suite: Error 1303: The installer has insufficient privileges
Cannot change category of in place family
How to control the order in which families with nested families appear in schedules
Revit crashes on Windows 10 Fall Creators Update
Revit Warning: Can’t place inserts outside of hosts
Does Revit support roaming profiles?
How to find the area of paint within a Revit model
“An unnamed file contains an incorrect path” error message when trying to overwrite a file in Revit ...
Autodesk Revit is crashing when trying to run COBie extension
Can’t render in cloud
How to change the elevation of lighting fixtures in Revit
How to separate the display of the different load \ load cases
Possibility to downgrade Revit update
REVIT - is it possible to verify Revit analytical model in Revit
Revit 2017.2.3 Update Failure - Error 1328
Revit crashes when starting a new family
Revit: How to understand and address warnings
Revit: Is it possible to drive a Family Type parameter with a value in a lookup table?
Taking a Fabrication MEP model into Revit - items dont seem to join node to node as they are in Fab
Unable to change the product serial number
November 2017
Collaboration for Revit: Can’t see Revit 2017 projects in Revit 2018
Double-click of vertical reducer annotation and changing sizes won’t adopt the reducer symbol if siz...
Revit 2017 .NWC export creates a .log file
Revit 2018.2 crashes on opening
Revit: Rotate tool greyed out when trying to rotate a view by crop region
Live Editor: Program automatically closes or doesn’t react when opening live files
Revit Live model won’t open in Live editor
Calculation rules of the Buildingbook extension in Revit schedules
is it possible to list the volumes of wall layers?
“Licensing System Error 6” when launching Revit
Activation Page Went Blank White Screen
Are there recommended model File sizes for Revit and Navisworks?
Autodesk Fabrication job imported into Revit does not show Service colors
Autodesk Point Layout - Slab Analysis color range setting in Revit
Autodesk Revit - IF formula in door schedules
Autodesk Revit - Reference planes went 2D
Cannot download the Autodesk Revit families from Autodesk Vault Client
Energy Analysis: Location Weather and Site script error
Error 0x80070718: Not enough quota is available to process this command
Error 0x80092013 while Revit is trying to access web services
How to apply Point Loads and Point Boundary conditions to wall corner nodes in Revit
How to change Beam Usage Types names
How to change the instance parameters for the title block of all the sheets
How to create a “closed” frame railing?
How to create canted walls in Autodesk Revit
How to cut point cloud with void extrusion
How to import point cloud into Revit
How to share Navisworks clash results
IFC, Buttons are missing at export
In section or elevation views in Revit, something is blocking the display of 3D elements
Insight Light Analysis in Revit - missing results for certain rooms
Installation issue with Site Designer Extension 2017 for Revit
Installation of Revit 2018 fails on C++ 2005
Missing elements error when upgrading Revit models
Pixilated or low resolution files when creating DWF \ FWFX files
Revit - Circular chain of references when modifying a stacked wall
Revit - Display issue with a window family in a curtain wall
Revit - Elements are missing after exporting a Walk Through Rendering
REVIT – Lightning analysis – Solar access analysis type – Raw data export option does not create any...
Revit 2017 crashing during start up
Revit 2017.2.3 update installation issue
Revit 2018.2 update only gives ‘Uninstall’ option when trying to install
Revit could not load C:\PROGRAM FILES\AUTODESK\REVIT 2018\ANALYSISAPPSDB.dll
Revit exporting to AutoCAD DWG brings objects to origin point
Revit models become corrupt after Revit Server is restarted during work session
Revit Precast extension causes hang-up when finishing group edits in Revit.
Revit print to file e.g. PDF filename does not match naming in Revit
Revit Structural Tag not populating
Revit Warning: Cannot copy selection
Revit_IFC-export fails at specific model in Revit 2018
Revit-Mouse Wheel does not zoom, instead it scrolls the view.
Revit: 3D solids and text are missing in 3D view when dwg file is imported into Revit
Revit: 3D view not showing families correctly
Revit: Acquiring and Publishing Coordinates
Revit: can you show two views of lighting analysis with different times on same sheet?
Revit: copied/pasted assemblies are given a new number
Revit: Host or projects are not visible when trying to glue from the BIM 360 Glue add-in
Revit: How to calculate required RAM specific to a project size.
Revit: How to keep size of Revit files manageable
Revit: Model crashing when saving coordinates
Revit: Synchronization crash with C4R project
Revit: Tag not loaded according to warning but it is loaded afterwards
Revit: The requested operation could not be completed because the model is not currently available
Revit: trees in 3D view are missing or appear as boxes
Revit: What are the capabilities of the Autodesk Structural Precast Extension for Revit?
Revit: Which Design Options are made available when you publish to BIM360 Team
ROBOT- REVIT link - tips how to make Revit model correctly and transfer it to Robot
Roof and stairs are missing after binding the model
Steel Connections for Revit - Dimensions in the plate settings dialogue
Structural Analysis plugin does not appear in toolbar after being installed in Revit 2018
Unable to edit Fabrication parts dimensions within Revit
Unable to launch Revit 2018: a small window appears on Splash screen
What applications are used by Autodesk Revit on a workstation
October 2017
Can I install and activate my single seat of Revit on multiple machines?
Revit - Error when accessing newly created projects in C4R
Revit displays Korean font incorrectly or blank in 2017 above
Revit family parameters are grayed out for certain families.
Revit: Unable to access any of the C4R projects
Failed to start the backend.
“ContentPackFinalize was not found” when installing Revit 2018
Activating Revit Architecture, Structure, or MEP 2016 - Contact your administrator message
All functionalities, but Navigation/ Orbit are disabled in Autodesk Live Editor at specific models
Autodesk Revit Insight 360 - Daylight factor calculation results
Autodesk Revit Insight 360- Calculation Engine for Daylight Factor Analysis
Can’t use keyboard shortcut for schedule export in Revit
Cannot access BIM 360 / Fusion Team Hub after changing email
Changing units or/and changing from drafting to model hatch in a Custom imported .pat text
Customize Revit Electrical Panel Schedule Template - remove phases
Default orientation is wrong with lights hosted on linked model’s ceiling
Dynamo preview window is blank
Error: “Could not connect to Internet Mapping Service” for project location
How to modify the View Title on a sheet in Revit
Insight 360 “There was an unhandled error on application.”
Live Design - Editor stuck at unpacking design file
Missing Revit 2017 Offline Help
Revit - display Family in fine detail regardless of detail level of view
Revit - Elements from level above are showing in floor plan view
Revit - eTransmit not working
Revit - Model disappears when enabling temporary view properties
Revit - overriding projection line color of a category
Revit - Shape handles missing in certain window families
Revit 2017: cannot modify the parameters of specific steel connections
Revit 2018 cannot start
Revit 2018 crashes with dialog box “An unrecoverable error has occurred.” when working on a project
Revit 2018: Windows Error - “Program has stopped working” upon launch. Event Log - Faulting module n...
Revit Error: the central model has been moved or modified
Revit Insight 360 - CIE Overcast Sky in Daylight Factor Analysis
Revit Legend color scheme cannot be halftoned
Revit Model crashes with varying error messages
Revit: “Can’t edit the element until "user” resaves the element to central and relinquishes it and y...
Revit: Copy compound element and result is individual parts
Revit: How to retrieve earlier published versions of a cloud model
Revit: None of the created elements are visible in the view
Revit: print walls with shading without showing shading in the project
Revit: Specific template is not generating views in the project browser
Revit.exe - Bad Image
Shape edit section box - zoom to fit
Some elements of .dwg files are not visible when linked into Revit
Support for Dynamo for Revit
The BIM 360 Team icon is missing from Revit 2017.2.2 Open dialog
Autodesk Revit Live: user permissions and URL`s used by the application
Revit: Hardware acceleration not supported for “” card
Extrusion tool bar is missing
Revit LT 2018 - Bad Image: DesktopMFC.dll Error Status 0xc0000020
Displaced shadows in Revit
Foundation is in wrong position under the wall
How are the room polygones calculated?
How to create a slanted wall end?
How to tag multiple masses in linked models with a single tag
Linked file path type is set as relative but Saved Path displays full path
Remove repeater crashes for specific family
Revit MEP Electrical Panel Board Schedule Blank
Revit Worksharing and Revit Server Diagnostics and Benchmarks
Cannot create rebar for in-place families in Revit
Column Filters by base Level doesn’t seem to work on “minus” levels
How to lock certain joins?
Is it possible to shorten the handrails' path?
Room bounding parameter for beams
“Error 1935. An error occurred during the installation of assembly” when installing Revit 2017
Curtain wall system won’t export to DWG in Revit
Error: Revit could not load C:\PROGRAM FILES\AUTODESK\REVIT 2017\ARRAYELEMSDB.DLL
How to change the display of a specific part of a toposurface in section view?
No elements visible in Revit views
Revit-Serious Error Occurred importing axm (FormIt) To Revit
Where does Revit save project-related data?
September 2017
Unable to run Revit Live if nested file contains linked file from A 360
Revit LT 2017 - CONCEPTUALENERGYANALYSISMFC.DLL Error
“Licensing System Error 1” errors when starting Revit 2018 only randomly,
After deleting all the view templates the dialog “Manage View Templates” is not any more available
Cannot dimension hidden edges of links
Disappearing beams in floor plan viewvis
Error: “The following render appearance images are missing:…” when rendering to the cloud.
How to create free form Rebar in Revit 2018
How to create/generate/save dynamic pdf / 3D pdf from Revit
How to reinstall the Collaboration for Revit Add-in
Miter join doesn’t work for beams with rotated cross section profile
Multiple Host Support one central file in Revit
Nested generic annotations get lost in the project
Print a Revit electrical panel schedule on A4 paper
Revit 2018 content library installed but templates are not there.
Revit Extension Integration with Civil 3D error: Connection to AutoCAD Civil 3D failed. Make sure th...
Revit printing error: File, Print Range and Preview not working
Revit Server 2017 does not connect server
Revit: Cannot undo delete views in worksharing projects
Revit: Display order of overlapping elements is out of control
Revit: Line scale problem
Revit: Query of Objects inside an inserted DWG-file fails
Revit: You don’t see bar engagement “0” in standard rebar coupler.
Running Revit 2017.2 Update stuck about half way
Strange selection dots in certain project with crash
System requirement for Revit Server Accelerator
When model text is cut by a plan region text frames appear
Revit Error: Some Void Forms of this family do not cut anything and will be deleted. To make a Void ...
Adaptive family does not schedule correct level
How to set 3D view same as 2D view
Revit 2016 R2 Update 7 installation error
Revit 2018 silent install with single server license
REVIT hangs when try to export the model to SMLX using Advance Steel Extension
Revit performs slow if there are too much detailed rebar model and Fine view set
Unable to install Revit 2018 on 32 bit Windows
When opening Revit it opens in Viewer Mode
How to reduce the split line of floor in Revit
Image on Revit family not printing
Impossible to install Revit 2018.1 update via Desktop App
Revit doesn’t allow to place a room if less than 300 mm wide
Revit hangs up when saving to network
Revit is slow on startup
Rotated Revit Label squashed text
How to place views on sheets in Revit
Single letter keyboard shortcut does notwork in Revit
Families and Templates folder are missing on Revit 2018 When installed from Building Design Suite De...
BIM 360 Team keeps Loading in Revit
‘Unknown error!’ When installing Revit 2018
“Licensing System Error 1” when launching Revit 2018
Revit - Cloud Rendering of RPC content appears duplicated and rotated
What is the thinnest line that can be output by Revit?
Remake doesn’t start after launching it
Revit cannot create local file
Using the command line to install Revit
Is solar radiation technology preview for Revit still available
Lost data after synchronizing with the central second time
No verification email is received after Revit renders in cloud
Purchasing Cloud Credits for Revit
Revit - Can’t select imported DWG
When exporting 3D views from Revit to DWG, an outline extends beyond the titleblock in the DWG
Error 0xc0000020 while opening Revit
How to change the attributes of an In-Place family?
Arrayed elements in wall based family display on diagonal when wall size is changed
“The digital signature needed for this install can’t be verified” when installing an update for Revi...
Area calculation in Revit using norms of DIN 277
How to Include Revit 2018 add-ins and updates with a deployment and install silently
Troubleshooting: Collaboration for Revit – Synchronize
August 2017
Insight 360 Daylight Analysis Fails with “unrecoverable error” in Revit
Revit 2017 installation fails with Install Now method error “Internal Error”
Revit 2018.1 update only gives ‘Uninstall’ option when trying to install
Revit: Reinforcement bars from IFC exported from Tekla Structures show up as generic geometry
2018: How to Complete a Clean Install and Uninstall of Revit products
Autodesk Revit 2018 on Mac OS X
Collaboration for Revit: Nothing happens when clicking BIM 360 icon
Collaboration for Revit: When accessing HUB files through the browser they are all outdated
How to move project data from one Revit Server host to another.
How to recover a deleted model in a Collaboration for Revit project
Place list in open dialogue doesn’t maintain changes in Revit
Revit - Topo surface contour lines ignores contour shape
Autodesk Revit 2017 on Mac OS X
Revit: Published changes of linked cloud models are not reflected in the central file
Revit: Insight 360 Daylight Analysis Fails with “unrecoverable internal error”
Revit 2018.1 Collaboration P&ID Modeler Error
Revit element (e.g. opening) partially cutting reveal causes entire portion to disappear
Revit: Shortcut buttons on the Quick Access toolbar are not displayed
Unable to export Revit 2018 model to Live Editor
Revit Live Editor will not open
Error: “Operating system is unsupported” installing Revit LT 2016
Revit: Deleting/Restoring Cloud models within the product
Tagging Revit Model Groups
Revit: Exporting/Importing from STAAD.Pro
Revit: Nested Electrical Circuit Paths are not placed correctly when host family is placed
Navisworks Switchback Not Working with Revit
Print dialog buttons are unresponsive in Revit
Revit - Room tags not displaying for certain users
Revit 2018 Update 1 fails to install with error “The file or directory is corrupted or unreadable”
Revit Import/Export Fabrication MAJ Job file: Revit could not complete the external command
A360 Desktop Version Expiration
Add-in for Revit only appears in administrator level
Arrow drag handle doesn’t show up in 3D view
Batch upgrading of Revit files
Decals not visible in Revit model in BIM 360
How to delete multiple parameters from a Revit family at once
Is it possible to cut the model text with void in family editor
Lighting calculation output from Elumtools to PDF is blurred
Revit - Cannot sync C4R model
Revit 2017: When you bind the project, space volume shows different results
Folder won’t open when trying to link a model in C4R
Revit Fabrication API 2018.1 External Tools
Revit 2017: Deleting Scheme deletes areas in different scheme
REVIT – Collaboration – Changes made to a linked RVT files not synchronizing
Revit LT: Is it possible to use plugin or addins in Revit LT?
Revit 2017.2.1 update only gives ‘Uninstall’ option when trying to install
Export Shared parameters button is disabled in the family editor
How to renumber Fabrication Parts in Revit
Revit 2018 error upon startup: FormIT Conversion Add-in Failed to initialize
Revit 2018 text delay
Revit Project Browser freezing when scrolling
Revit: BIM 360 Team button does not work
Revit: Export to IES VE
Revit: Users unable to synchronise with central model
When opening Revit model, the following error is received “Can´t edit element until resaves the elem...
Where to find Revit Content Libraries to download
Where can I use Collaboration for Revit?
REVIT – Cannot dimension ducts edges in a section / elevation views.
REVIT MEP - How to create legend for pipes and ducts
Revit: Server accelerator is skipped and not creating any cache data
How to make a wire visible on 3D view in Revit
“MC3.dll file missing” when installing Revit 2016 from Autodesk Building Design Suite Premium 2016
BDS user cannot download Structural Precast Extension for Revit 2018
Collaborate button missing from Revit 2018 ribbon
Re-activate your Subscription message with Revit 2017
Revit: Cannot use the “Save as” function
Unable to open Revit model after linked model update
July 2017
Manage the Cloud model performs too slow if Revit 2016 C4R v9 installed
Room boundaries are missing in a DWG exported from Revit
When you tried to borrow license, license page goes blank (Network License)
Resources for piping and cast iron pipe in Revit
Manually override the material to different color in Revit
System.IO.PathTooLongException when launching Revit after installing Advance Steel Plugin
Unknown error occurred when creating a new Revit local
User can´t access Insight 360 from Autodesk Revit
View prints lighter than expected in Revit
Warning message “This signed add-in has a security problem. What do you want to do” pops up every ti...
Where to get Structural Precast Extension for Revit and if there is Chinese localization version
Slope beam can’t show cut display by cut plane in plan view
Rotate Project North sometimes doesn’t rotate all elements
Navisworks 2017 Switchback functionality to Revit 2017 is not focused on the object as expedcted
Nested generic annotation in nested family does not show in floor plans
Problem doing Revit energy analysis when multiple users are logged in using the same username
Material in Revit family doesn’t appear when loaded into project
Licensing System Error 9 - Revit/Revit LT
Learning Revit through Lynda.com and CADLearning.com
Level field is missing from window and door instance properties
Is it possible to show pipe size, system, slope and elevation from bottom of pipe in one tag for the...
How to tag curtain wall mullions in Autodesk Revit
How to place a Railing onto Toposurface along with slope in Revit 2017 below
How to get “In Room” parameter for e.g Windows in Schedule for Multiply Categories
Hidden lines don’t show on sloped elements in Revit
How to access unlimited cloud credits in Education Community
How to add a new room to a room group in Areabook?
How to avoid warning message saying ‘The element has an open connector’
E-Transmit hangs on linked Revit model
Diamond shape rebar edit constraints
Duct insulation is not hiding even if Duct workset is turned off
Cannot host a reference point onto a line in the conceptual massing environment in Revit 2017
Collaboration for Revit: How to change a project thumbnail setting preview
Clicking on R button in Revit takes long time
Cannot select geometry of in place voids
Can’t align the vertical pipe by snapping the center of the pipe in plan view
Can’t apply color fill to rooms in Revit
Can’t make footprint roof due to error message when editing a roof
Cannot load family from the content library in Revit
Autodesk Revit - Solar Access Time Range in Insight 360
Autodesk Vault 2017 Revit Error: Exception: Unable to initialize the Dynamo Helper Service
Autodesk Revit - About the “Structural” instance parameter for levels
Architectural floor doesn’t show elevation at top survey in schedule
Advance Steel: “Operating system is not presently configured to run this application” error while op...
Revit - Cannot link DWG - Import detected no valid elements
Revit - Pipework friction tag is showing not all calculated values
Revit - Window family becomes off axis when loaded into project
Revit 2015/2016:A valid license could not be obtained by the network license manager
Revit 2016 Release 2 - Error 1642
Revit 2017, License Activation Window, Blank screen at First Launch
Revit 2017: crash when exporting Revit DB Link to Access 2007
Revit 2018 will not open if AutoCAD is already running
Revit Analyze & Energy Simulation
Revit Content Library Deplyment
Revit Crash - Unable to print/export particular sheet
Revit Energy Analysis - cannot create any energy analysis surfaces
Revit gbXML exported geometry contains gaps
Revit LT 2018 installation fails with Install Now method
Revit message “Encountered an improper argument” when editing materials
Revit model element properties are missing in Navisworks 2018
Revit shows blank white window and fails to start
Revit worksahred files don’t show up in an expired BIM 360 Team Trial subscription
Revit: 3D objects are represented in all the Detail View settings
Revit: After installing the 2018.1 update, the Open file dialog window misses the BIM 360 Team icon
Revit: Can the view direction can be changed in graphical column schedules?
REVIT: Cannot export a specific model to .SMLX using Advance Steel Revit Extension, error message ap...
Revit: Cannot hide annotations that are outside the cropped area from a linked view
Revit: Cannot tag the Structural Slab Level
Revit: DWG link rotates when reloaded
Revit: How can I open and edit my models directly from my BIM 360 Team hub?
Revit: Rendering materials are getting lost in Cloud renderings
Revit: What is a common workflow to import models from Tekla structures?
June 2017
Collaboration for Revit: Install files for each Revit release
Revit 2017-Can you select by ID from A360 on a dwf file.
Revit files in my BIM 360 Team hub are not available when using Collaboration for Revit
Revit 2018.0.2 Hotfix Fails to install
Revit: Serious error opening particular view
Revit: Project will not upgrade
Get Up to Speed: Autodesk Revit 2018
Released Revit 2018 Updates & Add-ins
Adding own materials to BIM
How to annotate wall opening - elevation from ceiling
2017: How to Complete a Clean Install and Uninstall of Revit products
Advance Steel: Can beam features be transferred to Revit?
Hidden line dashes aren’t lining up in Revit
Revit - Tiny icons & overlapping dialog menus
REVIT – Points cloud import – Snapping precisions issue
Revit 2018 installation fails with Install Now method.
Revit sheets not printing to scale
Troubleshooting Revit crashes
Unable to access BIM 360 in Revit 2017 running on Windows Server 2012
Revit plotting problem with HP Designjet
Revit-Column location Mark parameter indicates an offset although column is at grid intersection
Download RVT from BIM 360 Team: Failed to open document
How to make a multi-level cuttable family in Revit
REVIT – How to automatically populate room’s finishes parameters in rooms schedules.
REVIT – Section Line disappears when changing the plan view scale.
REVIT – Windows can be seen through walls
Revit warning - ‘A Pad can’t extend beyond the edge of a Toposurface’
Revit: “Failed to login by oauth” error message prompted when trying to glue model
Revit: PDF export/print options
Unable to bind the selected links if phase information is blank
BIM 360 Docs: Plans uploaded from Revit are blurred
Crash on files closing in Revit 2017.2
Error: Operation could not be completed upon sync in C4R Revit 2016 or Revit 2017
Nodes disappear in Graph View and only show wires in dynamo
Revit - Diagonal lines print jagged in pdf and physical printer
REVIT – Work sharing - Editing Request Notification not showing up
Revit files not syncing to central after project rollback
Revit: How to automatically change Central file locations of multiple files without breaking the fil...
Revit: Multi-selection will only move in one plane (e.g. only up/down or only left/right)
Revit: Unable to export file to Naviswork
Some objects are missing in Revit importing ifc from advance steel
Where to download the Insight plug-in for Revit
Can’t change dimension value of the whole length after using equal constraint
How to add constraint for the center of the circular profile
How to change default duct length in Revit
Revit export to DWG and characters are added to the name when zipping
Revit software does not show that latest update has been installed
REVIT – Performance issues when zooming in or out.
Revit elements from linked file showing incorrectly
May 2017
Revit LIVE crashing
Revit Live 2018: Erorr “No Head-Mounted Display is detected”
Shared Coordinates in Revit LT
Best backup strategies for Revit projects
How to change the default file location for families in Revit
How to dimension round hatch
How to replace a family in a project with a family of a different name
How to rotate the light source in xy plane and constrain it with angle parameter in a lighting fixtu...
How to upgrade Revit project standards
Managing section line visibility in Autodesk Revit
Moving a schedule between Revit project files
Not enough drive space - Revit Installation
REVIT – Cannot detach a wall from the floor located just above.
Revit Server - project related permissions
Revit: Adding Images to System Family Schedules
How to control the visibility of the nested annotation family in specific project view
What is the difference between Start/End Level Offset and Z Offset Value for structural framing
Revit and Plant 3D compatibility
“Fatal error” or “Unrecoverable error” when finishing a Revit stair
Autodesk Revit - Assembly codes and keynotes for Finland
Cloud Rendering Error: The Rendering service could not complete your request
Collaboration for Revit error: You do not have permission to edit the element
Collaboration for Revit: Error “Cannot Sync” or “Operation could not be completed”
Communicator for Revit will not sign in
Current Window option grayed out in Revit
Customized Revit 2014 Deployment, Project Path path error
Electrical circuits in Revit don’t respect odd-then-even numbering setting
Error “Rebar is placed completely outside of its host” when using ungroup
Error 1601 installing Revit (or Revit LT) 2018
How to add Analytic Construction values in Windows family
How to calculate individual roof area if it is sloped in Revit
How to create a nested half round fill detail item with variable radius in a lighting fixture family
How to install non-English contents for Revit without internet connection?
Link an IFC File after Revit project base point has been moved
Mass Flow Rate Parameter for Revit
Navisworks: Unable to modify anything in the file through Freedom
Opening IFC4 format is not showing object in Revit
Parameter type Electrical Potential cannot be used in Revit
REVIT – Ceiling plan views / Structural plan views – Windows’ Sill cap visible while it shouldn’t wh...
Revit - Model is being accessed by someone else and is not available on file open
REVIT – Properties palette and project browser frozen.
REVIT – Surface and volume values reported in schedules are incorrect for foundations
Revit 2017 subscription license issues
Revit crashes when not connected to the internet, or to limited internet
Revit Exception Errors On Opening and Switching Views
Revit fails to adjust space names to room names in linked model
Revit fails to snychronize with central due to system volume calculation
Revit IFC export missing linked models
Revit structural connections are missing in IFC export
Revit: “Specify Coordinates by Point” doesn’t display correct values
Revit: BIM 360 Team unable to view files from different releases
Revit: Calculated Value in schedule does not show expected results when Itemize every instance is de...
Revit: Can’t set material for cable tray in Revit
Revit: Elevations doesn´t follow curved walls
Revit: Insight- DOE-2 simulation failure: VERTICES are not counter-clockwise
Revit: Material Textures are not accessible/visible in the Material Browser
Revit: very long sync times
Revit: Will there be a Architecture, MEP and Structure version available
Revit: Is it possible to lock specific users from a project file?
Some tips when creating MEP fitting family
Structural Connection 2018 does not start or crashes while starting
Unrecoverable or Fatal error when opening/saving/synching a Revit model
User Interface problems in Building Design Suite Premium
April 2017
How to change the URL for a Collaboration for Revit A360 Team Hub
Revit 2017 disappears after clicking, “Enter Serial Number”
Revit - Workset & Phase settings lost when linked RVT is bound
Revit sloped Columns do not display pre-cut when “Show family pre-cut in plan views” parameter is en...
Revit: Using View Filter to control visibility Beams Based on Structural Usage
REVIT-How to join walls and slabs of different materials.
Deleting Projects in A360 Gallery
How to get room designation information into Revit families for use in Navisworks
Material tag for wall displays question mark
REVIT – Compound family – Nested family cannot be edited.
Revit 2017.2 does not upgrade Revit to version 17.0.1110.0
“Revit has stopped working” on launch - Event Log shows: Faulting module path: C:\WINDOWS\System32\K...
Hatch patterns of linked IFC models in Revit
Revit: How to remove InfoCenter bar
BIM 360 Glue: Surface patterns from Revit are not displayed
BIM360 Drive: When opening the local drive, the files in the folders are not synchronised
BIMTrack add-in blocks Collaboration for Revit
Can’t create dimension without dimension line
Changing view depth and bottom of view results in floors showing that are below the view range
Cloud Rendering Error: Your rendering could not be rendered because an error occurred
Contours on a Revit topography disappear after upgrading model to 2017 or later version
DWG imported in AutoCad MEP exported from REVIT loose the information about units
Elements disappear when creating a component in Revit
Error 1603 when installing Autodesk Personal Accelerator for Revit 2017
Error External tool failure when installing advanced steel extension into revit
Exporting NWC fails from Revit
Freeze Drawings and Content Generator - missing from Revit 2017
Is it possible to make parameter created in the family not show up in project
Massing in Revit Live
Missing MEP elements when appending Revit models into Navisworks Simulate 2017
Navisworks Manage 2017 error: The program can’t start because CollaborateFileNav.dll is missing
References of Revit files lost after uplaoding to Vault via Autoloader
Rendering result in Revit 2017 is different compare to Revit 2016
Revit - “Can’t obtain permission to edit the element” error
Revit - Cannot place gusset plate after placing base plate to column
Revit - layer separation lines of walls are missing
Revit - Roombook/Areabook/Buildingbook update returns an error
REVIT – Steel connection addin – Created steel connection cannot be modified “Modify parameter” dial...
Revit 2017 Font - Arial Black is displayed in italics
Revit 2017 font display changes on output
Revit crashes after selecting “Enter a Serial Number”
Revit crashes regularly when drawing walls
Revit From/To Room field blank in Door schedule
Revit Options bar is missing or blank
Revit server support files get huge
Revit Server/Navisworks: How to directly open a revit model from a revit server.
Revit Structural column display is incorrect in plan views when view cut plane is changed
Revit/Dynamo: Dynamo Code Block is not editable
Revit/Formit: Startup Error “Failed to initialise the add-in "formit conversation” because …… does n...
Revit: Family categories don’t have a “Room Calculation Point” Parameter
Revit: Family Geometry gets changed through insertion
Revit: Opening proces freezes when accessing V/G or object styles
Revit: Project base point deleted
Revit: Site Designer doesn’t appear on ribbon after installation
Volume is incorrect when geometry in the family has different detail level visibility setting
Why the DATACATEGORY column is empty in shared parameter txt file
March 2017
Cannot activate grid model endpoints in Autodesk Revit
Revit Server: HTTP Error 500.19 – Error Code 0x80070005 when browsing SVC
Revit - grids missing in views
Revit: Hangs when exporting a sheet to DWG
Installation of FormIt 360 Converter for Revit 2017 fails on Windows 10
Revit 2017 content upgrading from previous release
Collaboration for Revit: What to do in the case of an outage effecting Autodesk Collaboration for Re...
Revit - double-click on title block parameter opens family editor
Mask region doesn’t work when exporting to dwg
Revit model with .dwg link crashes
Linked walls disappear in section views using “Clip with line” setting in Revit 2017
Revit Error: Model Is Not Currently Available
Autodes Revit - influence of families on model performance
Collaboration for Revit: Connection Error Message / Temporary Service Interruption
Revit: English dialog boxes appear in foreign language pack
Revit Contents Library or Family Templates not installed
Revit - missing paper forms in the print dialogue
Saving a Revit file with Revit LT
Error -1601 when installing Revit 2017
What are the differences between Revit Server and Collaboration for Revit?
Revit Error: “A required resource was unavailable,” leading to Revit Crash
Revit Server Open dialog lockup
Revit view placed on sheet cannot be selected.
Revit: How to create a Material Library
Revit WorkSharing Monitor shows multiple listings of the same user
DBD BIM and Autodesk Revit LT
Revit - adjusting railing type
Revit - shadows in cropped floor plans and 3D views
Revit: Views and elements are locked/pinned and cannot be selected
How to send and receive Revit files that are complete
How to backup Revit cloud models
Revit: Level/Elevation indication is displaying the wrong value
Revit: Material Browser performance is slow and does not show preview
Revit 2017 check out BDSP 2017 license but opens in Viewer mode.
A360/BIM 360 Team Icon not showing in Revit 2016
Revit - Performing a relinquish all mine after sync to central gives a false error
February 2017
Unable to Pick Lines while creating annotation elements if objects are in secondary design option
How to use AutoCAD details in Revit
Linked Revit model has to be reloaded every time the host model is opened
Revit: Vertical cable tray
“Connection error - An Autodesk server may be down. Please try again later.” when launching trial ve...
Revit LT 2017 Licensing Error - Unable to initialize adlm. Internal Error Message: Error code: <20>
Section lines are missing in a Revit floor plan view
Revit: Bringing AutoCAD Plant 3D DWGs into Revit
Callout from linked file doesn’t show in the view of the host file
Can’t set subcategory for the hatch in filled region
How to move the break line on stairs in plan view
When Revit Hidden Line settings are changed for electrical, the settings for mechanical are also cha...
Revit: Is possible to have different size lists on different Flex Pipe Types?
Revit shows a blank window on launch after installation
How to display grand total rows only in a Revit schedule
How to bring a Plant 3D model into a Revit project
Revit Error | Autodesk Revit has Stopped Working
Circuiting 3-way switches in Revit
Revit: Location/map feature is not generating a map
About rooms and spaces in Revit
Collaboration for Revit - Host model views missing in A360 Viewer
Revit - calculating space above rooms in a hall
Certain model elements won´t get exported from Revit to IFC
Is the Revit Addin supported with Vault Workgroup
Revit Central file to Vault - Mapping issue
How to add supports to edges of multiple walls
How to extract reactions from one model and use them as loads in another
Some Room objects are missing after import IFC file to Revit
Editing section symbol appearance only changes in some views
Phases disappear from project
Revit 2017.1 Insight 360 lighting analysis demonstration
Wood shakes orient upside-down on wall sweeps in Revit
Is it possible to prevent worksets from deletion or rename
No Servers listed in Open/Save dialog after setting up Revit Server
Revit: Upgrading a project to a newer release
Error: Licensing System Error 2
Revit gives a stop sign (circle with a line through it) when using a command
Is it possible to keep wrapping when creating parts for wall
Revit: Objects created in worksets are not visible in the view
Revit: Roombook isn’t able to run on an existing project
January 2017
Autodesk Revit: EU host and region cannot be selected when glueing a model
Large IFC files at exporting ducts/ pipes with insulation
Revit: What does the latest service pack/hotfix contain
Revit How to Show hidden lines in component stairs
Cannot Mapping Autodesk Revit file bidirectional wit Autodesk Vault Property
How to work together with Autodesk Vault and Autodesk Revit ?
Collaboration for Revit: Service and Storage locations
Revit - BIM Objects Surrounded by Boxes
Matt DiMichele
