i don't understand why i insert a label and Revit don't put in center of family.
Attached video.
BIM Manager - HVAC and Plumbing designer ___________________________________________________________________________
Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums.
Solved by marco.defina. Go to Solution.
when placing a tag turn leader off.
the text box in the family and where the leader line is placed in relation to the body of text drives how it is positioned
try changing the Leader / Border offset to a smaller increment
@kadmonkee wrote:when placing a tag turn leader off.
I tried, change nothing…
@ToanDN wrote:
Edit the family and turn on Annotation categories to see if any box or lines are there.
I tried, there is nothing...
Attached the family if somenone want to see….
see this earlier post
@kadmonkee wrote:see this earlier post
Thanks, but this was not the problem. The problem was the position of each label in the family, i centered the text in the family and gone right.
