Issue with Constraining two Parallel lines
Hello all,
I am trying to build a shape for a family. Here's the deal..
At the top of this shape, you will see two lines that are running parallel to the Ref Level plane (XY plane). Off of these two lines, you'll see two lines that are angled going downwards.
What I'm looking for is the angled lines to run parallel to each other at a set distance apart, logically, the two lines above should be able to stretch accordingly to ensure that this happens. There are automatic dimensions in place that kind-of/sort-of does this. The problem is when I go and drop a dimension that controls the thickness of the parallel lines, the automatic dimension for the lines on top disappear. This causes issues and prevents me from doing what I want to do.
I've attached screenshots and the family file, can anyone shed some light on why this is happening?
Thanks.
