@HVAC-Novice
Thank you for reiterating the shortfalls of non PCI-E drives.
I agreed, a $50 difference from a 1TB WD Blue Sata III 6GB SSD to a Samsung 980 NVME 3.0 is not a big deal if you do in house builds but the bloated price difference from the manufacturer, we must use at work has a price difference of $150+/- dollars when opting to upgrade from a 1TB Sata III 6GB SSD to a M.2 3.0. NVME 4.0' are more like $250+/-.
What RAM do you currently have? We currently run our new builds w/ 128GB 8x16 DDR4 2933MHz Ecc, dont remember the timing atm.
Can I please see your bench marks? What software are you using/how have you benched the different drives? Need less Shadow of the Tomb Raider benches and more BIM/Local Revit 2.5-4.2GB Revit Projects. 🤓
Speaking of when you did these bench marks was this all local files or was it moslty BIM hosted files? As BIM file opening from the cloud and not having any CAD format links locally saved to R/W should really just be RAM and Networks speed at that point right? This brings me back to my previous post about barley having 2% when opening these kinds of projects.
We have in the past, had a BIM project that had CAD format links locally saved (Server) totalling 4.2 GB in addition to the cloud arch file and think a NVME 4.0 would really shine here as opening the project for some took, 40+ min even the lowest level drafter's pay would justify the bloated manufaturors price differance.
As I am still learning how BIM projects work could we have uploaded our CAD format links that had each user call to our server to R/W into the BIM cloud next time? What was linked was several past building projects done AutoCAD 2018 or maybe older years like 2014.
Look forward to hearing from you!
