International Color Codes for MEP services
Is anybody have a International Color Codes for MEP services.
RBA
www.TechRoom.bg
Hello there arent international color code.
Check this and ANSI standarts.
PP: Every coutry may have a serapate color code standart. I mean local government reglament for public projects.
I hope this will help you.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
thanks for your response. Yes that is correct it's different for different for countries and regions. Do you have any list of legends for all. I am basically looking for ME/UK and USA. -- Regards Renu Arora Jain
www.TechRoom.bg
USA works on ANSI standart and IPS. Click here
UK works on more than one standart right now: Click Here for ALL standarts. Every standart is setup for different part of BIM and managment in project.
BS 1192:2007 PAS 1192-2:2013 PAS 1192-3:2014 BS 1192-4:2014 PAS 1192-5:2015 BS ISO 16757-1:2015 Other standards
Eng. Iliev L.
i don't find any the guidline for MEP system colour in Revit. May you help me one more about the path, or you can send for me file according to the email : cuongphambcm@gmail.com
Thanks very much!
Best Regard!
RobDraw
I've not seen one.
Rob
debimmanager
This is the only guide that I have got. See link below
https://www.gsa.gov/real-estate/design-construction/3d4d-building-information-modeling/bim-guideline...
Kudo if you consider it and mark as a solution if it helps you solve your issue.
Thank you!!
Deivis E.
REVIT® MEP Specialist
