Insulation / Lining error on fitting.
craigjonnson
craigjonnson
The OOTB Breeches revit fitting shows the insulation / lining at a horizontal plane when the duct is set to an offset. I recreated the family and still have this error. These are being flagged up in clash detction, and we require this to be correct when shwoing the ductmakers and guys on site which insulation has been added.
Changing the fitting type to a transistion does correct the 3D view, but in plan the fitting dissapeers. All other fitting type categorys have the same error within this family.
ADSK - Do you have a fix for this. This error is evedent from 2012 - 2016 platforms.
craigjonnson
OK, So with further testing the problem seems to be the 3rd connector. The code for applying insulation / lining will work fine with 2 connectors and by assigning the duct fitting category to "Transition". Adding the 3rd connector, whatever it is that automatically applies the insulation / lining falls over on itself and cannot handle more than 2 to finish its task.
So this seems to be a program bug rather than a family bug. Great!
