Inconsistent Units in boolean Yes/No formula not working
revitworkbench
revitworkbench
hello I have been using formulas to calculate boolean outputs for years, however now in t 2018 it appears that it is not working?? What the heck happened? What am I doing wrong? Thanks
Just type
"Tier 2_4D Unistrut" in the formula box, no need for "if... 1, 0"
Secttor
@revitworkbench or you need [Tier 2_4D Unistrut] in this format inside the formula.
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
robert.klempau
Hello @revitworkbench,
I agree with @Secttor and @ToanDN.
In your case, you need only to put the parameter Tier 2_4D Unistrut in the formula.
But if you want to use an IF statement in a boolean parameter YES/NO parameter, just do the following:
IF (<condition>, <result-if-true>, <result-if-false>)
for YES/NO parameter:
IF (<condition>, 1=1, 1=0)
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
