Importing Calculated Design Loads from Trace 700 gbXML file into Revit
As the title says, I have imported the gbXML file containing all the results from my Trace calculation into Revit. I am curious though as to why Revit, it would seem, is ignoring latent heat information from the trace calcs when displaying the calculated design loads for each of my spaces.
I have attached a snippet of one of my rooms where I have highlighted in yellow the information that Revit is using for design loads and I have underlined in red the information that I want to use for design loads.
Skelly_PLAISANCE
Hello @Anonymous,
I do not know the software "trace", I imagine that its utility is close to the software climawin.
Yes, latent heat information is a good idea, post it here please :
https://forums.autodesk.com/t5/forums/postpage/board-id/302/load-autosave/true
Skelly_PLAISANCE
Put in answer the weblink of your software' editor please.
