import Excel data to Revit family parameters
ammad.mahmood
ammad.mahmood
hallo everyone.
I am working on a project in which i am modeling pipes and fittings etc through P & id Modeler by Revit. So each element in P&id drawing is associated with some data eg 10 parameters and the settings in the P & id modeler provide only to map the tag between the Plant 3d and Revit. Which means i can only bring the tag into my Revit.
so, now each element eg pump has its own tag but besides tag there are also 9 parameters that i want to associate with each each pump. And all the pumps are different from each other, in other words all of them are separate families.
i have all the data in excel. Can you please guide me how can i bring other 9 parameters from excel and associate it with each element. I know it can be only be done with dynamo but i don't know how to use it. i am a beginner and i will definitely learn it but now for a project i need this . Can someone please help me with the script? if you have already made one? or if there is any other way of doing it or may be some plugin availabe?
franciscopossetto
Hey,
To get started with Dynamo I recommend you to read this guide:
https://primer.dynamobim.org/
What you want to do is a typical workflow on Dynamo, you will find similar solutions on Internet. You can have a look at the Dynamo forum:
https://forum.dynamobim.com/
You can see this thread:
https://forum.dynamobim.com/t/using-data-from-excel-to-set-parameter-values-for-all-elements-of-a-ca...
And have a look on this nodes:
1. To importa data from excel:
https://dictionary.dynamobim.com/#/Office/Excel/Action/ReadFromFile
2. To Get Parameter values:
https://dictionary.dynamobim.com/#/Revit/Elements/Element/Action/GetParameterValueByName
3. To Set Parameter:
https://dictionary.dynamobim.com/#/Revit/Elements/Element/Action/SetParameterByName
4. To filter Elements based on certain conditions:
https://dictionary.dynamobim.com/#/Core/List/Action/FilterByBoolMask
I hope it helps,
Kind regards.
Github:
https://github.com/franpossetto
ammad.mahmood
Thankyou so much for the links. I will have a look into it.
