IFC Elements/Components missing in Revit but visible in Navisworks
We received a Ventilation-Model as  an IFC-Model from our Customer. We are using REVIT 2017.1 and the IFC-Modell was generated from a higher version of REVIT. Some parts of the ducts are missing and in some sections there is a single line array of rectangles as duct.
But when I import the the Model in Navisworks, the elements are visible with an exception of Duct-Accessories shown in black. The picture with black background is from Navis and with the white from Revit.
I look forward to possible solutions and suggestions.
robert.klempau
Hello @Anonymous,
Is your mapping correct?
You need to map the IFC classes to the right Revit Categories.
Hope this helps a bit to get your IFC file into Revit.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Hallo Robert,
Thank you very much for your reply. I had mapped the elements (attached pic) but had linked the IFC-Model. Now I have opened the IFC-File using open IFC menu and I am able to see all the elements but a new problem has arised that the Air-Duct are classified as Pipes.
It would be very helpful of you if you could link a mapping table in your reply.
Thank you.
