IF statement using 2 lookup table columns
mark.j.eaken
mark.j.eaken
i have two columns i want to use in a lookup table using a if statement and greater than.
if(nominal diameter >4", column A, column B) is  what i kind of looking for
if greater than 4" than column A if not then use column B
i'm not sure how to write it.
this is what i think it should be but doesnt work
if(Nominal Diameter >4",size_lookup(Lookup Table Name,"TO2"),size_lookup(Lookup Table Name,"TO1")))
ceyhunyuzuak
just in order to give it a try I placed this formula into one of pipe elbow family and it works as intended
if(Nominal Diameter < 80 mm, size_lookup(Lookup Table Name, "FID", 1.08 * Nominal Diameter + 5.2 mm, Nominal Diameter), size_lookup(Lookup Table Name, "BOD", 1.08 * Nominal Diameter + 5.2 mm, Nominal Diameter))
maybe you might want to consider to upload your family so I can take a look what's wrong with it.
also in your formula it seems Lookup Table function is missing 2 out of 4 (at least) variables.
on the other hand you can combine several lookup table into one lookup table so you can use your formula search multiple variables through single lookup table.
iainsavage
I might be wrong but I’m pretty sure that you can’t use a size range for the lookup value and that it has to be a distinct value which matches the value in the lookup column(s).
This link might help.
https://forums.autodesk.com/t5/revit-mep-forum/some-tricks-with-this-lookup-table/m-p/6877957
I think it would be easier to edit the lookup table so that the found value in the rows for 1”, 2” etc up to 4” will have the A value and sizes 5”, 6” etc will have the B value, the A and B values being in the same column on the appropriate rows.
