I can't see 2023 cloud projects on Revit 2025
isosa9APBT
isosa9APBT
I been working on a Revit 2023 project for the last couple of months with an architect that works on another program and I been using IFC files for the design. I recently received Revit structural and they are in Revit 2025. When I try to open Revit 2025 using the Autodesk docs option and I go to my account where the 2023 Revit MEP is located I can't even see the folder. I only see two other projects that started as 2025 from the start. How do I upgrade my 2023 Revit MEP file to be 2025 if I can't even seem to be able to access the folder. Has anyone experienced this before?
To view different versions, go to Revit Options:
To upgrade all cloud models in a project, open ACC > Docs > Settings > Cloud Model Upgrade.
isosa9APBT
That worked, but the place where I found it for this particular project looks different than the one you show. I have a question that always confused me. There seems to be two different but similar Docs interfaces. There is one like the one you are showing and I can see with some of my projects. What is the difference between the two? When I start my programs I always get the second version, should I be doing something different to get one version over the other?
GaryOrrMBI
"I have a question that always confused me. There seems to be two different but similar Docs interfaces."
There ARE two different interfaces (because there are two different versions of Autodesk Cloud projects).
The older BIM360 Document Management interface/version.
The newer ACC Docs interface/version.
When a project is created it is tied to the interface/version that it was created in. To "move" a project from one to the other can't be done at this time. The only current option for that is to create a new project in the desired version/interface, then download all of the files from the original one and upload them to the other one.
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Eric5XSJX
Observer
Observer
Also, since the update you may need to open the Autodesk Desktop Connector and go to "Select Projects" to check which projects you want to synchronize with Revit 2025. This was the case for me when I couldn't see specific project folders on the Cloud.
