HVAC test and balancing software
KFSam
KFSam
As a mechanical contractor we use Buildingstart software to handle our HVAC test and balancing and commissioning. Is there any other software that does the same thing but integrates with Revit? Does Revit have there own version of this type of software?
So much time is spent exporting/importing data out of Revit and into this software I would assume someone has figured out a better way to do this.
Thanks.
HVAC-Novice
What specifically do you need the software to do? Duct or pipe, or both?
Keep track of the measured values and iteration when adjusting balancing dampers?
What do you usually import from Revit specifically in your current workflow?
Their website doesn't' explain what exactly they do unless you do a demo. Do you already have that software, or just looking into it?
Revit version: R2025.4
KFSam
We currently use the software. Our commissioning department uses it to track the equipment start-up process. So we export our equipment schedules out of Revit and import that data into Building Start. From there our commissioning crew can add notes to the software, for instance, flow of a pump or measured air flow out of a diffuser.
We also use the software to create the Equipment tag. It's just a very tedious task to export/import. With data always changing we have to export multiple times and re-enter data. We export/import equipment data like: flow, power, manufacture, model #, location, service, temperature etc...etc.
We also use it to keep schedules and much more, but that doesn't really impact Revit stuff.
I know Bluerithm has a Revit add in. I'm thinking they're the only ones that integrate with Revit.
HVAC-Novice
You probably thought of that... but if you use a Revit-based solution, everyone needs a Revit license installed. This usually isn't the case for commissioning agents or contractors. Revit also isn't great for mobile devices and wouldn't work on non-windows devices.
Maybe you are more looking for a solution to make the exporting more efficient? I assume much depends on the designers using specific formats for schedules etc.
Anyway, I don't have a solution for you. Maybe I still mis-understand your current process and needs.
robert2JCCH
Please correct me if I'm misinterpreting your workflow:
  • Export equipment schedules from Revit to some datatype that can be accepted into your TAB software (or manual entry)
  • Population of real-world values from TAB report into TAB software
  • Export of TAB software to some datatype? Or manual entry to Revit?
  • Revit tagging for display of values on plans/sheets.
I suppose the first question to ask would be: does your TAB software export to a txt or csv format?
If this is the case, then you have access to delimited data, which means that you can use Dynamo to interpret the file and populate Revit. What you would do is provide a common identifier of equipment between programs (Pump P-1, Air Handler AHU-1, etc...), use that to build a dictionary of values from your TAB software, and then have Dynamo plug those values into Revit for equipment with corresponding IDs.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
