How to set Air Terminal with 2 connection?
marco.defina
Message 1 of 25
marco.defina
i have the situation in the images below...I need to have 2 connection on a single air terminal. I setted on one the right information of classification and direction. The second connection only fitting connected at the first...
But when i want to have the pressure lost or i check the ducts systems i receive error...Wrong direction fluid...
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
Accepted solutions (3)
Replies (24)
Message 21 of 25
iainsavage
I can’t test it the moment but maybe this will help.
If I recall correctly the grille box was a duct accessory and the flow division was done in that component rather than the air terminal.
https://forums.autodesk.com/t5/revit-mep-forum/duct-flow-throughout-the-system/m-p/10325500#M78842
Message 22 of 25
marco.defina
Yes, but it's a workaround. Thanks
I think Autodesk can resolve this issue.
Message 23 of 25
RobDraw
You can call them work arounds if you want but they are solutions. That's what this forum is for. If you want to get Autodesk to add a new feature you should go to the IDEAS forum instead of being rude to those people trying to help.
Rob
Message 24 of 25
marco.defina
I understand what you say, but Autodesk wrote to me in 2018, after i opened a support request, that they will push to make this improvement in the future. It's been more of 4 years, that's all...
And, yes I agree with you, workarounds are solutions
I do not feel that I have been rude to anyone. If it seemed, I'm sorry.🙂
Message 25 of 25
iainsavage
I’m not entering the whole workarounds versus proper solutions debate but consider this please.
When you purchase a slot diffuser that is exactly what you get - the slot diffuser face, in pieces for site assembly. You then need to purchase the plenum boxes as an accessory (and usually specify length, height, number of connections, diameter of connections etc). Same for most other grilles and diffusers - you buy/specify the grille or diffuser face and you then have to buy/specify the box as an accessory.
So perhaps it is correct to see the plenum with the two connectors as an accessory (Duct Accessory) rather than as an integral part of the air terminal? So maybe Revit is reflecting real world practice in that regard?
PS: I wasn’t offended by your remark but thanks to @RobDraw for defending my honour anyway.
