In Manage<Panel Schedule Templates<Edit Template, add a Calculated Parameter (Discipline=Common, Type=Text), and use the formula below. This is not the exact formula I have seen in the past, just a remake of it, so it may require some minor tweaking.
-When opening the Panel Template, click a column where you want to insert the "WIRE" value, this will 'un-grey' your calc param box. (The button it greyed out because I am already in the dialog box)
if(Rating > 200 A, "ALERT", if(Rating > 175 A, "#3/0", if(Rating > 150 A, "#2/0", if(Rating > 130 A, "#1/0", if(Rating > 115 A, "#1", if(Rating > 100 A, "#2", if(Rating > 85 A, "#3", if(Rating > 65 A, "#4", if(Rating > 50 A, "#6", if(Rating > 30 A, "#8", if(Rating > 20 A, "#10", "#12")))))))))))
This will pull info from your Rating parameter, to "schedule" a Wire size without splitting up all the wires in a run. If you do not have a Rating parameter, you will need to add a column, then assign it a parameter function from the drop down menu on the left side.
**Be aware this is not a substitute for wire sizing and scheduling. Simply a work-around. Verify all wire sizes produced by formula.**
-Please click accept as solution if this answers your question!
