Announcements
how to make a revit family tag from dwg file
danezeq
danezeq
Hey everyone
I apologize for my question being unclear, it's hard for me to phrase it on english. i'll try anyway:
i want to take this formula (with an attribute in it) on cad file, and make an identical revit family file, that display this formula, with a revit atrribute ( i think it's called 'label' on revit)
this formula designated for HVAC plans.
fabiosato
If I understood your need, L= is text, A is a parameter (area type) and m² is a text.
If this is correct you can create a label as below.
This refers to the parametric text, the arroew must be created with filled region and lines, if you want to control the arrow direction, it will be manual, create an instance parameter and toggling it you display the arrowhead on the left or on the right, you have to create two filled regions and two yes/no parameters to control the visibility of each one.
Fábio Sato
