how to isolate a single element in a linked revit file in revit 2024
irving.garciaHUXY4
irving.garciaHUXY4
How can I isolate an element in a linked revit file? I want to isolate the element in magenta which has a mark name under the identity data, so I used a view filter to make it magenta but now I want to just isolate it alone. Any suggestions using an add in or a dynamo script ? Screenshot 2025-02-05 135926.png
iainsavage
Set a view filter to "does NOT equal" [whatever your criterion is], then use that to turn off visibility for everything which doesn't have the specified criterion.
irving.garciaHUXY4
Thank you so much that worked! This is my first time using filters.
baleti3266
that's a really useful trick in revit, it can work across categories and across links
