How to have a line style show one way, but plot another way,
I have started with this company called AEI. We are having trouble deciphering between some of are lines because of colors being so close, but if we change it to a different color, then it is to close to a different pipe. The company doesn't want to change fully to dashed or "letter" in line style, due to client requirements. Is there a way to permanently change a line style in a template so, that it can show dashed or with a "letter" in it, in design (model) space and print (paper) space solid? I know you can use filters in a way, but you have to create filter and apply them to every view on every project. So, I would like to change it in the line styles pre-loaded in template and call it a day. EX: ( I will use a cold supply and return for example) so, these the line are both blue, but so close in color we have to stop and select line to make sure we are connecting to correct pipe and then continue. But, if we could have the returns show up dashed or with a "R" in them, in our working area (model space), but still show up in plots (paper space) as normal solid lines, it would be great. Is this possible? If so, how and is there any reading or video (how to) material on this?
Zach
