Revit MEP Forum
How to give same electrical phase for the circuits in same space?
5 REPLIES 5
943 Views, 5 Replies
As per the regulation here, no two phases are allowed in one room in villas. I have a bed room with two lighting circuits and one power circuits. Please help me to put everything in one phase, say R phase. Revit automatically assigns to other phases.
5 REPLIES 5
piotr.bocian
in reply to: piotr.bocian
Thanks for your quick response.
Yes. Thats possible.But the tag i added to lighting layout doesn't get
updated when i change the phase in panel schedule. For example, i shifted
Y2 circuit to R3 in the panel schedule. But still the wire tag in the
lighting layout show Y2, which is not acceptable. Please help..
Yes. Thats possible.But the tag i added to lighting layout doesn't get updated when i change the phase in panel schedule. For example, i shifted Y2 circuit to R3 in the panel schedule. But still the wire tag in the lighting layout show Y2, which is not acceptable. Please help..
piotr.bocian
To which parameter of wire property the wire tag is associated to? You are not able to do it automatically, because phase is not a parameter of wire.
Thank you all. It was a temporary issue. Once i closed and re-opened, its working fine. Thank you very much to all.
