How to get 1/10" pipe slope
revitworkbench
Message 1 of 12
revitworkbench
How do I get 1/10" pipe slope? Everything Ive tried, including changing the project units, only allows 13/128" what gives? Please let me know where I am missing it. thanks! Capture.PNG
Replies (11)
Message 2 of 12
kadmonkee
from an earlier post i commented on.
follow the link.
https://forums.autodesk.com/t5/revit-mep-forum/new-slope-value/m-p/7023836#M40110
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 12
revitworkbench
@kadmonkee
Hi, thanks, but I dont think you understand my problem. I know HOW to create a new slope. The problem is that you cant create exactly 1/10" per foot. If I type in 1/10" / 12" it returns 13/128" / 12". Sorry I should have made my question more clear. See all the other, nice clean pipe slopes in my picture of my original post? I want that, just for 1/10" slope too. thanks!
Message 4 of 12
kadmonkee
have you tried changing the ratio?
thank you
Message 5 of 12
revitworkbench
Hi, no that doesnt work either. Here is a better picture, of how revit is changing what I want for no reason:
Message 6 of 12
kadmonkee
in the format dialogue box have you unchecked use Project settings?
thank you
Message 7 of 12
revitworkbench
@kadmonkee
hello,
Perhaps you are thinking of a schedule? I am not talking about the schedule, I am not trying to schedule the slopes. I am right in MEP Settings from the manage tab. The highest in the hierarchy.
Message 8 of 12
kadmonkee
the images I posted earlier relate to options within a project
it may effect schedules but these are project units settings
select the slope button to open the Format dialogue box and confirm the settings
if the Use Project Settings box is checked you may not be able to override this value
thank you
Message 9 of 12
Evan.S.Hall
@revitworkbench, Did you ever find a solution to this? I have a similar problem as I'm trying to slope pipe 1/40" per 12" and the closest Revit allows is 3/128" per 12".
I'm thinking that we are out of luck due to the limitation described here, but maybe there is some kind of work around?
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-064B3C67-29FA-49AA-8BB3-E118FB28C3E5
Message 10 of 12
RobDraw
That's 480' until you get a change of 1". I'm curious as to why you would need to that kind of accuracy. It could be accounted for with the flexibility of most materials.
Rob
Message 11 of 12
Annotation 2019-12-30 091537.jpgAnnotation 2019-12-30 091558.jpgAnnotation 2019-12-30 091634.jpgAnnotation 2019-12-30 091705.jpg
Message 12 of 12
Lev97
1/10" = 13/128 looks correct to me. (.1/12)*100=.84% slope.
For example:
1/4" = (.25/12)*100=2% slope
1/8" = (.125/12)*100=1% slope
