How to extend the hexagon line
pe_simon
Message 1 of 8
pe_simon
I want the hexagon all side line extend distance from 30mm to 50mm at once time..
I made the parameter at all side but error.  Thanks.
Replies (7)
Message 2 of 8
fabiosato
For such kind of geometry extrusion, I suggest you use Sweep or Swept Blend with profiles.
You can create a profile family, using reference plans to control the size, and these plans will not clutter your geometry family
Fábio Sato
Message 3 of 8
evan_grady
I just ran into this problem recently the way I was able to make them all move equally is by using a extremely small set of reference lines in the hexagonal shape at the center of the hexagon. Then I used the align dimensions tool to set the distance I want from each side of the small hexagon to each side of the larger hexagon.
Message 4 of 8
hmunsell
if you not wanting to adjust it using parameters, just select the entire shape and use the scale tool.
Howard Munsell
Message 5 of 8
pe_simon
I wanting to adjust it using parameters, because I have difference type and difference size hexagon...
E.G
Type A 30mm distance hexagon
Type B 50mm distance hexagon
Message 6 of 8
evan_grady
@pe_simon With parameters see my example above it will work for your application. It is the only way I have been able to figure it out. Just set up a tiny hexagon of the same orientation as a reference line in the center of it. Then use algin dimensions from the smaller hexagon to the larger one for every side and then create a parameter and set all those dimensions to that parameter. I put in an idea for them to make polygons adjustable by the radius/diameter of the circle you draw it out originally with. This is the link if you want to vote for it: Parametrization of Polygonal Families Using Radius/Diameter of Surrounding Circle - Autodesk Communi...
There is also a family below with the setup you are looking for:
-Evan
If this helps, please like and give a solution
Message 7 of 8
pe_simon
Thanks.
Message 8 of 8
fabiosato
Here is a profile to be used with Sweeps and Swept Blend.
Fábio Sato
