how to edit the display parameters
gabriel_glehn
Message 1 of 13
gabriel_glehn
Please, How can I customize and edit the first image attached to become like the second?
Replies (12)
Message 2 of 13
rendermaster
can you be a bit more specific for what is that you want....
1. editing the model on the first image to become like on the second image is not applicable, they are not of the same family, the first one is  lavatory, the second one is water closet.
2. why do you want to edit the first model, if you can replace in instead with second model
not sure if i answered your question well. otherwise, pls be more specific to your query.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 3 of 13
s.borello
Can you please elaborate on what you're actually trying to accomplish?
Message 4 of 13
gabriel_glehn
Sorry, I don't think I was objective.
1. In the image 01 is my software: the diameter, flow direction and image texts indicating the type of category are on top of each other, I would like to separate them to read the information better
2. I attached one more image to try to be more specific with. Because I do not know the name of this label.
3. in picture 02 i showed how I would like these texts to be
Message 5 of 13
rendermaster
those text are just labels and will appear once you highlighted or selected that model, they are just guide for you to see the diameter of the pipe for tapping purpose. They are not printable and will not show on your drawing. If you wish a clear view of those labels, zooming in and out will do. Their location are not editable
Message 6 of 13
gabriel_glehn
Yes I know that those texts are just labels
but I do believe that it’s possible costumize this label... because for me it’s horrible to undestand what is written there, and for my friend it’s just good.
zooming don’t turn it big or separated.
I do believe it is editable. If you look the pictures you will see clearly, both have same zoom and different appearances
Message 7 of 13
RobDraw
Not at the user level. You would need to be a programmer at the factory to do it.
You are comparing two different families.
Rob
Message 8 of 13
gabriel_glehn
@RobDraw
____________________________
If you see the picture 03 you will see, its the same one. Am I wrong ?
Does the plumbing fixtures labels looks like mine in picture 01 and 03 ?? if you try with others families you will ever have the same, I tried with the same object that my friend have and same template and looks so diferent this labels  T_T.
Message 9 of 13
gabriel_glehn
@rendermaster look this picture (04) please. It has a great zoom but looks like the same. thats impossible to read... this is really annoying me T_T
Message 10 of 13
RobDraw
Actually, it doesn't matter. You cannot directly edit the appearance but you can decrease the size of the text by adjusting your "Temporary dimension text appearance".
Rob
Message 11 of 13
gabriel_glehn
@RobDrawThank you a mililon, it worked for the size, please look this picture (05), the text is big but it's confused because the text is on top of another
Message 12 of 13
RobDraw
Make it small and zoom in.
I've got nothing else for you.
Rob
Message 13 of 13
gabriel_glehn
@RobDraw thank you so much, unfortunately zoom in doesn't work, i tried many times with a smaller text .
