How to delete the design option?
kevin_peter
kevin_peter
I am working on linked model.
I have made design optins to linked model as primary.
I do not want to use the design options. Now i can not select the wall or other things.
I have to come the desgin option then change to primary model, then i can select.
can someone tell me if i delete that option in design option, will i be at risk loosing the linked model?
robert.klempau
Hello @kevin_peter,
So if I am correct, you have a design option and have a linked model in the Primary option of that design option set.
If you have only one Option in your Option Set then that option is the primary set.
You will see everything that is in the Primary set in your Views.
When you select the Option Set and select the Accept Primary button all the elements in the Primary option will be selectable again in your model.
The Option Set will be removed from the Design option list.
Note: if you have more options in your option set and you select the Accept Primary button, then all the elements that are in these non-primary options will be deleted.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
kevin_peter
Thanks .Great job
