How to control the rotation of the Label of a annotation Family
Hello Everybody!
I'm currently facing a problem wich i can't solve
I have my electrical fixtures properly modeled, and they are represented in plan view through an annotation family.
The problem i have is that the text of the label (wich show the power of the electrical fixture) is being wrongly positioned.
I'm atacching a picture in wich this problem is better explained.
I wish that the unselected electrical fixtures labels are represented the same way that the selected ones are
Thank you all!
rudi.roux
Hi @Anonymous
I hope you are well! Smiley Happy
If I understand what you're looking for, then you can do the following:
Go into your family annotation symbol, then without selecting anything, have a look at your properties pallet inside the family editor. Change the parameter values as shown below.
Next, select the label which you created and change the parameters as shown below:
This will then leave you with then end result as shown below. Is this what you're looking for?
I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
