Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How to change dimension from mm to cm,not using the project unit command
kevin_peter
kevin_peter
How to change dimension from mm to cm,not using the project unit command.
Beacause i do not want to change my pipes height into "cm".
Can someone help me ?
jeroen_vanmassenhove
Edit the type properties of the annotation you are placing.
In there, change the Units format to not match the project settings but to whatever you like.
As always, duplicate first so your earlier placed annotations don't change as well.
kevin_peter
Thanks a lot mate.
It has worked out.
Bent u een belg?
aysenakahraman98
same question but how can we do that with Revit API
fabiosato
Create a dimension that use the units you want and use this type to create the dimensions
Fábio Sato
