- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have two circuits (circuits 1 and circuit 2). Both feed from the same panel (panel H). Each circuit feeds receptacles, 6 receptacles each. If I go to move one (1) receptacle from circuit 1 to circuit 2, it wants to move all 6. Is there a way to move just one receptacle? I would like circuit 1 to have 5 and circuit 2 to have 7 receptacles. I have even removed the receptacle in question from the panel and Circuit System so that it is blank in the Properties of the receptacle, yet when I add it back into the other circuit, it wants to bring with all of the other receptacles that it was originally associated with. The Waring is "You have selected elements that are already part of other Circuits. They will be removed from the original Circuits and added to this one." Even though none of the parts highlighted are part of another circuit.
