How to Bind Link/Copy Paste without missing Elements
Sujan.Maharjan
Message 1 of 8
Sujan.Maharjan
Does anyone have any way to bind links (MEP) without losing any element and as fast as possible? Whenever I Link and Bind in a blank document many elements are missing especially Tap fittings. I have tested this with multiple projects with the same issue. What I understand is Revit Copy Pastes Elements from one File to another File and I have faced the same issue when copy-pasting between the same file when Copy Paste Aligned to Selected Level/Current View.
"Revit Lies in the tension between what we want to do and what can be done!"
Replies (7)
Message 2 of 8
ennujozlagam
you can refer to this LINK and see if helps. thanks
Message 3 of 8
Mohamed-Nassar
Hello  @Sujan.Maharjan
Try to export this model as IFC File then Link it again and Bind
Try to make copy monitor to this elements there are more than 5 elements u can Copy/Monitor
Finally try cleaning this file delete annotations and tag let it contain only the model then audit it and purge unused familiy and material to keep it super simple file then try to Bind again i think one of those methods will be acceptable for you, Good luck and i hope to hear from you if any one works well with you.
Best Regards,,
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 4 of 8
JM_K
Sujan,
Just a thought, but if the file you're binding the linked file into doesn't have the System definitions and various items in the Routing Preferences setup in it then that might explain the loss of some elements.
I'd suggest opening the linked file and the host file side by side and in the host file, use the Transfer Project Standards tool to import all the system settings, fittings etc. Then do the bind link to see if that fixes it.
Worth a try 😉
Insert witty comment here.
Message 5 of 8
Sujan.Maharjan
Hi, @JM_K Thanks for replying. I have tried it and the result is similar. The main problem area is Tap connections which keep disappearing.
Message 6 of 8
Sujan.Maharjan
Hi, @ennujozlagam  Thanks for replying. It is saying the problem is specific to "In-Place Mass extrusions".
Message 7 of 8
Sujan.Maharjan
Hi, @Mohamed-Nassar  Thanks for replying. Exporting to IFC is not idle in my situation.
Message 8 of 8
Mohamed-Nassar
you can open the 2 project in the same revit them copy to clipboard what u need from a project to another. have u try this
