Hello, I'm trying to apply materials to a duct system family, but I've tried everything and I didn't find a proper solution.
I already know how to apply materials to pipes and structural system families, but as far as I've seen, no one on the interweb knows how to apply materials and external image textures to duct systems familes. Does any of you know how to do it?
That would be very helpful. Thanks!
Can't help with external images, but I've had success using the paint function to approximate materials on ducts.
@Anonymous is this sort of what you're looking to do? Note, you can duplicate/rename duct systems to create more than the default Supply, Return & Exhaust systems.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Hi, @Matt__W! It's almost that. I finally got a solution. I found out that I can apply a material on Object Styles and that solved my problem. Now I can upload image textures to duct system materials.
