How to add pipe sizes on MEP fabrication Parts ?
JPaul21
JPaul21
Is it  possible to modify or add sizes in MEP fabrication parts ? It always happens to me that when i try to use the design to fabrication tool in revit an error pop ups saying that there is no available size in the loaded fabrication service. Please see the attach photo for reference.adasdasd.PNG
pawel.romaniuk
@JPaul21
Could you share sample file? Which Fabrication configuration are you using and Revit template?
Pawel Romaniuk
Attached is a screen shot on how to add sizes. Click on the default pipe to bring this menu up. Hope this helps.
JPaul21
imperial content v 3.05. and also another question, how did you do to add those configuration because right now only 4 configurations appear on my revit.gsdgf.PNG
JPaul21
Yeah, that's right. I tried it but it is not applicable on fabrication parts.
JPaul21
I'm currently using revit 2020. See the attached photo for your reference.gsdgf.PNGtemplate.PNG
MOatman
Currently Fabrication parts have to be edited within AutoCad Fabrication CADMEP software.
Open up the Fabrication CADMEP software and see link below.
https://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/2...
