How to add pipe and pipe fittings in same schedule?
omar.amohamed
omar.amohamed
I want to create a schedule that contains pipe and pipe fittings in the same schedule with parameter size, count and system.
Something like that:
hmunsell
Unfortunately you cant.... they are 2 different categories.
maybe a good Ideas forum topic though....
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Howard Munsell
iainsavage
For pipes you probably want the “length” parameter rather than “count”.
Count only tells you how many pipes you have but it would normally be the length of each size that you would want to quantify?
