How to add coupling to pipe?
fabiosato
You must have a pipe fitting which part type is transition, and set it to the routing preferences in the type properties.
Also this transition component should work according to the pipe sizes on both ends.
If it is not clear I can explain better later.
Fábio Sato
rudi.roux
Hi @Anonymous
Welcome to the community! Smiley Happy
Did you manage to resolve your issue? Did Fabio's input help you?
Below is an image to explain the workflow:
1. Select a Pipe Segment
2. Click on Edit Type
3. Click on "Edit" Routing Preferences
4. Add a Transition Fitting, either to all pipe sizes
OR
5. Add another Transition Type Fitting with specific sizes (Last image).
Last Image, additional Transitions with Specific Sizes associated.
I hope this helps! Smiley Wink
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
