How to access load classification of a project from within a family?
kevin_kuang
kevin_kuang
I have a list of load classifications defined within a project and I want to assign the classification to a receptacle family. In the family I have different types that I wish to assign to different load classifications. So I have a connector and the connector is assigned to a type parameter that is of 'load classifications' type. But when I click on the assign button, the list of load classifications I've created within the project is not shown. Instead there's only one or two load classifications shown that i created.
Does anyone know how to bring load classifications from within to project to the family?
Thanks.2019-01-04 15_45_12-Autodesk Revit 2018.3 - [3D View_ View 1 - -JBox - Flex Label Height Subscript.r.png2019-01-04 15_44_35-Autodesk Revit 2018.3 - [3D View_ View 1 - -JBox - Flex Label Height Subscript.r.png
piotr.bocian
Go to Manage tab and select Transfer Project Standards, you need to have project opened, so you will be able to select the project as copy from, next select Electrical Load Classifications to copy.
fabiosato
If you change the load classification, in the edit type within the project file, all load classifications in the project will be available.
 I like this option, because if you develop more than one template, this option will be more helpful, because the load classifications in the family are added to the project file.
Fábio Sato
