Dears:
there is diameter to be inputed, but why the inputed valve "77" still can works?
there should not be a norminal diameter of 77, should be 65 then 80
i am confused, for not konwing how look up table works,
question 1: i can't find any diameter named "Diameter", why i changed the valve , the fitting changed?
question 2: acoording to formular if can't seach the vlave in table the return valve will "0", why i input 77 , no "0" come out
question 3: i found the parameter unit is inch, is that the reason cause this 77 happened?
question 4: document stated "Lookup tables are used for pipe and conduit families to define parameter values in an external comma-separated values (CSV) file." ,then what if i want to use lookup table for c-channel, can it still work?
qustion 5: document stated:
LookupValue(1-N) | value to find in the first, second, and subsequent columns of the table. (When looking up values, the first column is skipped.) |
then which case are the first column will not skipped?
