How do I change index color to actual color?
evagilmore2022
evagilmore2022
Hi, I exported some drawings from Revit to DWG and the actual colors turned to only index colors on AutoCAD. It looks like the colors have been inverted.
How do I solve this issue other than selecting every single line and change them one by one which is a very tedious process. Please help, thanks!
RobDraw
Change your export settings. It's the button with ,,, on it in the DWG Export dialog box. The first tab is your layer settings.
Rob
evagilmore2022
Thank you, will try that.
evagilmore2022
Thanksss 🙂
