How do I adjust this diffuser tag to show the center line?
jcourtneyJMKUW
Observer Observer
jcourtneyJMKUW
Observer
Observer
Hello, I'm struggling to get things to behave the way I'm used to. I was able to get my diffuser tag to look pretty close, but I'm having trouble getting the center line to completely show/not be broken. Am I able to adjust the placement of the text within the tag? Or is there a better/correct way to show this?
bjlottis
You'll have to edit the tag family. Are you familiar with the process?
There are three different things you could change to fix this:
  1. Move the CFM label down away from the centerline so it doesn't hide the line.
  2. Change the CFM label text style's background from Opaque to Transparent.
  3. Reduce the CFM label text style's Leader/Border Offset to 0" or something close to that so it hides fewer objects around it.
I hope that's enough to get to going.
mari.shimode
Hi @jcourtneyJMKUW, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Mari Shimode
