Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Hide workets by filter
6 REPLIES 6
626 Views, 6 Replies
All our worksets name are grouped by discipline..(ex.P-SANR, E-Powr, M-Duct)...I want to use a filter to hide/show worksets but the "filter rules" for worksets really dont allow me just to select workets that begins with "P-*","M-*",
or "E-*".
I know I can use the workset tab in visibility graphics and "hide" the worksets but I'd like to use filters instead.
Any ideas?
6 REPLIES 6
CoreyDaun
Nothing you can do besides create a View Filter for each Workset, since there is no "Contains" qualifier. That's what the Worksets tab under V/G is intended for.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
I was hoping there was a trick out there....I needed to hear that from somebody else....Thank you.
you can do. but what is the use of that.
you can create a filter by using "filter by" as workset and equals as filter name.then you can do with visibility on or off.
i thought that you need like this only.i was attached a jpg.
CoreyDaun
You're right - basically the Filter-by-Workset is for applying specific colors or other graphical overrides. What he was looking to accomplish was to be able to turn all Worksets that contain "M-", "P-", etc. on his elec plans, as well as do the same for the other disciplines. Not a bad thought.
harinarayana55,
CADastrophe is right...In this project we are working on there are a lot of pipe systems/type/name.
Mechanical guys come up with a new workset everyday. So when I open my plumbing views I see
a new workset that I have to turn off/hide. But with a filter that can hide all worksets that begin with
 "M-" will take care of all present & "future" worksets....
CoreyDaun
I have created filters that control multiple Categories at once for each discipline, such as "Lighting - Coordination", which can turn off or halftone non-discipline elements.
If you have three or fewer Worksets on your View, you can set is up as:
Workset
Does Not Equal
"Workset1"
AND
Workset
Does Not Equal
"Workset2"
AND
Workset
Does Not Equal
"Workset3"
This way, everything except for those three Worksets can be hidden.
Forma Design Contest
