hide for a smaller scale than
lucashel_aci
Observer Observer
lucashel_aci
Observer
Observer
When creating a section on Revit, the parameter "hide for a smaller scale than" is by default in 1:100, I would like to modify it so that no sections disappear if I create plans in 1:100 or more.
Are there any solutions?
Thank you in advance
iainsavage
The "hide at scales coarser than" value for the section view, when created, does not default to 1:100, it defaults to the scale of the plan view in which it is initially placed.
So if you want it to be visible in every plan view regardless of scale then you would create the sections in a plan view at your coarsest scale.
Having said that, your views will become very cluttered at coarser scales because you will just see a mass of section line symbols (hence why that parameter exists in the first place.
1:100
1:500
