HELP! Switchboard panel schedule load summary section doesn't line up
krythe.arensman
Message 1 of 8
krythe.arensman
Revit 2017.2.3
As you can see, when placed on a sheet, my Switchboard Panel Schedule's load summary section doesn't line up with the rest of the Panel Schedule.
I have the Panel Schedule set to 10" width.  In 'Modify Panel Schedule Template' when I select a row all the way across the load summary and select 'Resize Column', half the time is says 9.2000" (which is the actual width that it appears as on a sheet), and half the time it says 10.0000".  When it says 9.2000" and I change it to 10.0000", all the columns reset to equal spacing, but on the sheet, it stays 9.2" wide with the .8" indent on the right.
I've drawing a detail line to show a dummy last column on the right to line up that section with the rest, but its driving me crazy trying to figure out how to get it to appear correct.
Help please?!
Replies (7)
Message 2 of 8
That's pretty typical.  The load summary contains different information than the schedule itself, think of it as a separate embedded schedule.
Message 3 of 8
krythe.arensman
That doesn't solve the issue.  The Schedule should be uniform total width across for all sections, Header, Circuits, Load Summary, & Footer.
In my custom built Panel Schedule, I want it 10" wide, which the Header, Circuits, & Footer are. However, the Load summary is only 9.2" wide.
THAT'S AN ERROR
Its only aesthetics, but its VERY jarring to look at. I'm currently using detail lines to fill in the gaps, but that's a band-aid, not a solution.
Message 4 of 8
patil.vaishali
Can you send file to check just with template and sheet details?
Vaishali Patil
Electrical BIM Specialist
Message 5 of 8
Without seeing the template itself I'm not sure what to tell you.  All of my panel schedules and load summaries are equal widths, and all of the column widths are adjustable.
Message 6 of 8
krythe.arensman
I'm uploading an exaple project. Its in in the OotB Electrical template instead of my custom template, and my custom switchboard panel schedule is still doing the wonky width game. I did transfer in all project standards from my electrical template. Also in the example project in my custom branch panel schedule which isn't have the width issue.
Message 7 of 8
deactivate_beensd
Hi Bryan,
Thanks for bringing this to our attention. At this time, this unexpected behavior is being investigated by the product team to be fixed in a future release of Revit.
Best regards,
Message 8 of 8
patil.vaishali
Saw your template, couldn't find the issue in the same but making new template with "Switchboard Panel" standard template resolved the issue.
Vaishali Patil
