half-round fill (detail item) with variable radius
dtiemeyer
Advisor Advisor
dtiemeyer
I would like a detail item that I can use a parameter to change the radius of a half-round filled region. Does anybody have a working version of one of these?
the white is the detail item filled region, the yellow circle is my light fixture family.
My other CAD is a Cadillac and I like to Revit to the Max!
kadmonkee
have you tried adding a radius parameter during edit sketch mode and include both the circle and the filled region?
I created a circle and added a radius dimension then added the radius parameter
next I created a filled region to represent the half-moon during sketch mode I add a radius dimension to the filled region and included the radius parameter to that .
and now finish the sketch.
Attached is the result
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
rdoFP2RL
Hey @kadmonkee  I realize this post is from awhile back and I'm hoping you're still around. I am trying to accomplish the same task, it's very simple I create a circle, dimension it, create a radius parameter, then create the filled region of a half circle and dimension that radius, and tie that radius to the created parameter. When I try to change the radius parameter I am getting a constraint error. I downloaded your file and works fine, I am not sure what I'm doing wrong. Hoping you can help, thanks!
kadmonkee
it could be the half moon linework is not actually associated to any parameters or reference planes / lines
open my example and turn on all visibility graphics (dimensions and ref lines planes etc.)
I placed somethings in sketch-mode so they wont display in regular mode
thank you
