Ground conductor & Correction factor
rvsn6K4R6
rvsn6K4R6
Hi
We specify the type of wire(Al or Cu) to be used. How and what values will be considered from ground conductor & correction factor table in calculating the wire sizes?
Thanks & regards
ricaun
Here have all the technical stuff about Wire Size:  Wire Sizing Reference
The Ground Conductor & Correction Factor you can change on the Wire Material section on the Electrical Setting.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
