Graphical Issues in Revit 24
jlarueZA8QE
jlarueZA8QE
Community Visitor
Community Visitor
I am having this issue in Revit 24 that I can only describe as phantom lines. I have attached a picture for clarification. This happens pretty much across all my models. The lines only appear within the boundary of mechanical equipment, regardless of the family. If anyone could provide insight that would be greatly appreciated.
Basam.Yousif
When you say "across all my models" I see that as a possible model template, view template override, or content elements you always use, hence the repeat issue.
It could also be that your graphics drivers are missing or outdated. Do you get the same when you print to PDF?
Can you make a sample model and share it? we will be able to tell if issue shows up for me or not.
