Generate Lighting Takeoff
gstewartESRR7
Observer
Observer
gstewartESRR7
Observer
Observer
Hi - does anyone know of a way to export a lighting takeoff from Revit automatically? Current workflow requires us to calculate a w/sf for each space by hand. I am hoping there is a way in Revit to either do this automatically, or to export the lighting fixtures or tags per space so we can do this quickly in excel. Thanks,
scott_dakin
You can create a formula that uses Actual Lighting Load or a similar parameter to generate this.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
I may be misunderstanding your inquiry here, but the workflow to get from a schedule to Excel is pretty straightforward.  To make this “automatic” would require some more work, maybe a Dynamo script.
In the image below, the steps were:
  1. Create a Schedule
  2. Include Room number and/or name as a field.
  3. Sort on one of those fields
  4. Export schedule
  5. Open in Excel
I hope that helps. If not, please elaborate further on what you’re after.
If my reply was helpful, please "Like" or click the "Accept Solution" button below (or both).
Martin Stewart
AEC Support Specialist
shujath36
What I understand so far is you want to calculate the lighting load of a particular space/Room. If the lighting is done on the model and proper load is assigned with load classification then you can easily extract the data under Multi category schedule. Check the image attached.
