Hi Mdengusiak,
I understand you have ceilings drawn both as ceiling elements and floor elements in your Revit project.
To your questions 1. and 2.:
1. I am trying to understand where is explanation to each surface type?
2. what is difference between floor and ceiling?
Differences in reality and in the architectural model:
Floor elements in Revit were meant to represent the construction dividing building levels, ceilings are rather constructions of the interior design, such as compound ceilings for example hanging from a load-bearing floor above them. Floors tend to have load-bearing functions while ceilings are more often constructed in order to hide unaesthetic building elements such as mechanical equipments above head. Mostly they cannot bear any other weight but their own and probably some integrated leightweight fixtures such as lighting fixtures etc.
Revit has different properties and parameters for these 2 kind of building objects - so it handles them in different categories and system families.
You can read more about them in the Revit Help menu here:
About Ceilings
http://help.autodesk.com/cloudhelp/2015/ENU/Revit-Model/files/GUID-15615B41-B1B2-4B72-86CA-3ECF8729A...
Floors
http://help.autodesk.com/cloudhelp/2015/ENU/Revit-Model/files/GUID-8099AC26-F02D-4C9A-9209-AAD95A10D...
Differences in the gbXML analytical model:
The gbXML analytical model is based around the definition of rooms which are superimposed on the underlying Revit architectural model. Any gbXML subsequently generated is based on the analytical model only and not on the underlying Revit architectural model.
Rooms are identified based on bounding elements such as walls, floors, roofs, and ceilings. The gbXML data exported from Revit is based mainly on rooms and their bounding elements. The DesignBuilder gbXML import mechanism identifies and converts these rooms into blocks and zones. Other building components like doors, windows and shading surfaces are created automatically as well.
In the case, you describe, you probably have set some ceilings as room bounding so the analytical model doesn´t recognize the "real" room bounding floor above those ceilings. Make sure to uncheck the parameter "Room bounding" for the ceilings.
You find detailed information about the gbXML model and it´s surfaces here:
file:///E:/01_Downloads/Training/db_revit_tutorial_v1_185.pdf
To your question no. 3. - can I somehow change this ceiling to floor?
You cannot change a ceiling to a floor by one click, but you can use it´s geometry to recreate the floor from the ceiling in case the floor is actually missing. You probably won´t need it once you have corrected the ceilings in the architectural model setting them as non-room-bounding, but in case you happen to need to use ceiling geometry to create floor:
- Go to Ribbon > Architecture > Build > Floor
- Specify properties of your floor as you wish
- Define floor geometry by using "Pick Lines" of the existing ceiling´s boundary
- Finish Edit mode
- Delete ceiling
I hope you´ve found this information helpful. Please, mark it as a solution if it answers your questions.
Thanks.
