I am trying to export a gbXML file from a Revit 2017 model, in order to re-use it in some other software.
Actually, the export itself succeeds, but the import in the other tool fails. I'm trying to understand what could be the cause.
So, it kept it very simple. Here is the situation:
So, what could be the cause of the fail? I tried 3 different gbXML readers, it fails on each one. The gbXML itself seem ok when you open it with a text editor..but that's it. Can it be linked to these numerous faces on the ceiling? Or to the Air gap? If yes, would there be a way to "tell revit" to simplify these ceiling surfaces in some way?
Thanks a lot for any help!
Would it be possible for you to share your file or only the part of the file that contains the space so we could try on our side ?
Regards
