Hello!
I've checked the forum about the problem, bust sadly I didn't find anything.
I have multiple AHU's in different location. The exhaust air system is common, all flow is set to the correct in the duct branching. For design the AHU, I want to check the duct systems Pressure loss, the system are well connected, I can inspect the system, but the AHU is not in the model. I closed all duct ending in the engineering rooms, and set additional flows, only one point is opend. When I select a duct, I can see the flow, and all the mechanical information. When I did the Pressure loss report, two brnaching had a flow rate 0, but a huge pressure drop. When I inspect the system, the two system shows 0 flow rate. All the directions are fine, the two prolematic system is connected, by tap. I attached a few pictures, hope it will help. When I Ispect, the lower level ducts have a blue arrowed inspect, and the upper (from AHU2) have red arrowed.
What can be the problem?
