Flex Pipe System Name
safakgunes
safakgunes
Hi everyone,
Is there an automatic way to change the system name of flex pipe when i connect it to my pipe system? Just because i am seperating piping systems according to different blocks and floors and when i connect the flex pipe i have to change it's system manually. My FCU connections are heating supply, heating return, cooling supply and cooling return but my pipe system name is like "block a heating supply". I asked around about this and people say flex is different from pipe systems so there is no automatic way. Any suggestions?
kadmonkee
if you already have predefined pie Systems you can select the system type you want from the properties palette
when placing the Flex Pipe define the system prior to connecting it
it is not Automatic though
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
