Revit MEP Forum
Fire Protection Systems Custom Families File Size Issues
2 REPLIES 2
466 Views, 2 Replies
I am attempting to create an archive library of BIM files for various valves/trims (fire protection systems).  I am using different file types for this, but my specific question is for the Revit files.  (Actually, I have 2 questions):
1-  How do I decrease the Revit file size for the 3D model while retaining the shape/appearances?
(I brought the .stp file into CAD and made it a block then brought it into Revit.  The files are between 7 and 10mb)
2- How does Revit store these models in the project? Does it keep one for reference and place it into the views as needed while keeping a 2D stamp or tag elsewhere? Or is each instance being counted in the file size and stacking up? It does make a difference how the software uses the model. I want to design these most efficiently.  Some projects can use hundreds of files.
2 REPLIES 2
Apparently, Revit will use the 3D files/ families in as many instances as are shown in the views.  Otherwise, they are not adding to the file size.
Answer to question (2).
fabiosato
The converted file from STP usually makes the family too big.
I suggest to create extrusions to replace the converted file, the size probably will drop below 1mb.
As long as I tested, having multiple instances does not increase the file size in the same amount, it seems it work more as a block with many insertion points. Instance parameters will impact in file size too.
Fábio Sato
