Filter/hide generic annotations in linked models?
russellvee
Message 1 of 9
russellvee
I suspect I know the answer, but does anyone have a workaround for hiding generic annotations nested in linked models without having to set up custom linked model view settings for every single view? For example, architects like to nest generic annotations in their families that say things like "Refrigerator" or "Dishwasher" in large bold text which shows up as big as a room and through the roof on a site plan. Since filters don't work on annotations the only options seem to be hide all generic annotations in the view (including the ones we want to keep) or set up custom view settings in every single view to hide all generic annotations in the linked model. Am I missing another way to do it?
Replies (8)
Message 2 of 9
RSomppi
Not using "By linked view" in visibility settings for the links should turn off all annotations in links.
Message 3 of 9
russellvee
I'm using "By Host View" in a brand new default view. To hide the nested generic annotations ("Refrigerator", U.C. Refr.") I have to hide the family types they are nested in or I have to change link display settings to custom so I can hide generic annotations in the linked model, which requires custom settings for every single view template (power, plumbing, hvac, etc).
Message 4 of 9
RSomppi
This is what I do.
Message 5 of 9
russellvee
Yeah that method is a lot more work and when the architect updates something you have to change every custom view template again. It's almost like the program is designed for architects.
Message 6 of 9
RSomppi
A lot more work than what?
You shouldn't have to make changes for updates.
The program was originally designed for architects but that is irrelevant these days.
This should be really easy. Maybe there is something that's missing from your description of the content?
Message 7 of 9
russellvee
Autodesk wants me to say my question has been answered but the only solution is what I was looking for a workaround for.
As far as I can tell, here is the quickest process for a consultant to add a linked model that includes some generic annotations nested in families.
  1. Click on Insert Tab - Link Revit
  2. Since we work with this architect frequently, all of their typical generic model garbage is already hidden in our view templates using filters, EXCEPT FOR THE NESTED GENERIC ANNOTATIONS which can't be hidden with filters for some reason.
  3. Open the list with the dozens of view filters that are set up in our template.
  4. Click on view template #1
    1. Click on V/G Overrides RVT Links
    2. Click on Revit Links Tab and change from "By Host View" to "Custom"
    3. Click on Annotation Categories tab and change <By host view> to <Custom>
    4. Deselect the checkbox for Show annotation categories in this view
  5. Click on view template #2
  6. Click on view template #3
  7. Click on view template #4
  8. Click on view template #5
  9. Click on view template #6
  10. Click on view template #7
  11. Click on view template #8
  12. Click on view template #9
  13. Click on view template #10
  14. Click on view template #11
  15. Click on view template #12
  16. Click on view template #13
If you need to add another linked model, just repeat the entire process!
Message 8 of 9
RLY_15
The way that you are describing this, all of your View Templates are set up to Include V/G Overrides RVT Links.
The faster answer might require some buy-in......but don't do that. If you leave it unchecked, it enables you to make:
View Template #14
1. Just the changes you want for RVT Link display. Ignore all other parameters.
Select all views -> Apply Template Properties -> View Template #14.
This approach is generally useful to address what I would otherwise describe as 'consultant quirks' - them doing things that make sense to them that make no sense to anyone else. For instance, them copying MEP equipment but not monitoring it so now updates stop being live and you have duplicate equipment in the wrong locations and now you have to turn off entire categories in your linked model so that you can see your current work and not the work you did a month ago.....yeah.
Message 9 of 9
russellvee
Ok that's actually a decent workaround. I've used that method before with CAD backgrounds (a view template that only applies to imported categories). Sometimes we do use custom V/G overrides for links in certain views, but I can't think of any reason we need to have them controlled by the template. I just have to remember to not apply the link template to any views that have other custom link settings. Thanks!
